CSCvo26128 - SG550XG-ReportingTaskIP6M - UNIT ID1 - OSFATAL:caught segmentation fault exception at address 0xc
We are getting below error and switch reboot frequently , we are using SG 350 - 28 port switch.
%SYSLOG-F-OSFATAL: caught segmentation fault exception at address 0xc signal-num = 11 (SIGSEGV) signal-code = 1 (SEGV_MAPERR) reg[00] = 0xaa105604 reg[0 1] = 0x1 reg[02] = 0x0 reg[03] = 0x0 reg[04] = 0xaa105604 reg[05] = 0x1 reg[06] = 0xaa128864 reg[07] = 0xaa12888c reg[08] = 0x0 reg[09] = 0x3c reg[10] = 0x1 FP = 0x0 IP = 0x28 SP = 0x7befeaf8 LR = 0xb5927714 PC = 0xb59242c0 CPSR = 0x600f0010 Fault Address = 0xc Trap no = 0xe Err Code = 0x15 Old Mask = 0x0 ***** FATAL ERROR ***** Reporting Task: IP6M. Software Version: 2.5.0.83 (date Jun 18 2019 time 16:44:23) base_address=0xb4705000 ros(+0x78a5f0)[
polppol
I also got this error on
SG350XG-24F
Firmware Version (Active Image):2.5.0.90
%SYSLOG-F-OSFATAL: caught segmentation fault exception at address 0xa8100356 signal-num = 11 (SIGSEGV) signal-code = 2 (SEGV_ACCERR) reg[00] = 0xa80fd3f1 reg[01] = 0xa80fd356 reg[02] = 0x0 reg[03] = 0x0 reg[04] = 0x3000 reg[05] = 0xa80fd4d2 reg[06] = 0x4fbfe9c0 reg[07] = 0x4fbfe9ec reg[08] = 0x0 reg[09] = 0x4fbfe9bf reg[10] = 0x4fbfe989 FP = 0x0 IP = 0xf0 SP = 0x4fbfe7a8 LR = 0xb4eda9f4 PC = 0xb4ed7a00 CPSR = 0xa0030010 Fault Address = 0xa8100356 Trap no = 0xe Err Code = 0x17 Old Mask = 0x0 ***** FATAL ERROR ***** Reporting Task: BNJR. Software Version: 2.5.0.90 (date Sep 26 2019 time 16:12:12) base
OSFATAL - caught segmentation fault exception at address 0xa7bfd000 signal-num = 11 (SIGSEGV) signal-code = 2 (SEGV_ACCERR) reg[00] = 0x506fd41c reg[01] = 0xa7bfd00a reg[02] = 0x14 reg[03] = 0x10000 reg[04] = 0xa7bdb484 reg[05] = 0x0 reg[06] = 0x506fd684 reg[07] = 0x1 reg[08] = 0xa7c05018 reg[09] = 0xa7bfcef2 reg[10] = 0x0 FP = 0x5 IP = 0x506fd534 SP = 0x506fd3b0 LR = 0xb53ffc34 PC = 0xb44f2380 CPSR = 0xf0010 Fault Address = 0xa7bfd000 Trap no = 0xe Err Code = 0x17 Old Mask = 0x0 ***** FATAL ERROR ***** Reporting Task: STSB. Software Version: 2.5.0.92 (date Nov 26 2019 time 13:25:31) base_address=0xb46e9000 ros(+0x78aed8)[0xb4e73ed8] ros(HOSTG_fatal_error+0x10)[0xb4e764dc] ros(OSSYSG_fatal_error+0x2a0)[0xb5441854] ros(+0x785aa0)[0xb4e6eaa0] /lib/libc.so.6(+0x25050)[0xb44ba050] ***** END OF FATAL ERROR *****
