CSCvq67348 - Cisco Identity Service Engine Authorization Bypass Vulnerability
amitmara
IS THE VULNARIBILITY AFFECTES ONLY LIMITED TO 2.2 VERSION OR IT IS AFFECTING 2.6 PATCH 7 AS WELL.
Leo Laohoo
This bug is assigned the CVSS ID of "CVE-2019-15255" and a more detailed information of the vulnerability can be found here:  Cisco Identity Services Engine Authorization Bypass Vulnerability
In the Affected Products section, it is stated:
At the time of publication, this vulnerability affected Cisco ISE Release 2.2
Since you are a Cisco staff/contractor, you should have faster access to reach out to the author(s) of the document to get an up-to-date information.
Hope this helps.
amitmara
Thanks for the information
