CSCvt31126 - ENH allow http-only-cookie for web connection
anybody else have this issue or know the patch from Cisco? i have not see anything from Cisco for this bug.
thanks
9 Replies 9
ttran32
Internal vulnerability scanner picked up this vulnerability and have been looking for a resolution as well.
Aomar bahloul
This issue has been carried over from the ASAs, Cisco Bug: CSCvt31126 - ENH: allow http-only-cookie for web connection
On the ASA they had a fix for it but apparently no workaround for the FTDs. Also, the severity was lowered from 2 Severe to 6 Enhancement go figure! I opened a TAC case for it even thought I doubt they will have a fix.
Hey Aomar, Did you receive any response from Cisco? I am having a similar problem like this case.
Yes, with the FTDs you need to use FlexConfig, first you need to create a Flex Object than attach it to the device FlexConfig Policy here is how the object looks like:
Aomar, I tried with the flex config policy, one of the situations that occurred to me is that when applying it once we performed another deploy the policy disappeared, for this problem is that in the Deployment field we must add Everytime, but apart from this we realized that by enabling the policy we would lose the anyconnect download Portal over the internet, so we decided it was better not to apply it after all. But anyway, thank you very much Aomar.
cball111
I have tried creating this flexconfig item, but each time I deploy, I get the following error:
error :
@httpOnly
ERROR: % Invalid input detected at '^' marker.
Config Error -- @httpOnly
Any idea what I am doing wrong?
Hey @cball111
I don´t know exactly the reason of the error, but try adding the "conf t" coommand at the beginning, example:
configure terminal
        webvpn
             httpOnly
Or instead try with this:
webvpn
    http-only-cookie
Configure Terminal also produced an error. However, the second option works!
Salman Mahajan
We will be providing a UI option to enable the 'HTTP Only Flag' in FMC 7.7, which is the targeted release for next year.
