CSCvt56923 - FTD manual certificate enrollment fails with "and" (ampersand) in Organisation subject field
John Hinckley
Why is the fix for an ASA?  This is FTD.  Cisco please post the Firepower fix.  Thx.
mgrzesia
Hi John,
The problem cause is in LINA code, which is shared between FTD and ASA. For now the integrated releases are only internal builds. You will see fixed FTD versions appearing once they are published.
Kind regards,
Mateusz Grzesiak
