CSCwh80060 - APs connected with 9800 WLC losing Flex WLAN VLAN mapping
Hi there,
If anyone is struggling or has struggled with the CSCwh80060 issue, like I have, I encourage you to read my observations and perhaps to use the script that can easily check for vulnerability to this bug. I hope this will help someone in some way.
Check it out
I encourage you to share your observations.
Hi Adam
I had this issue too. Cisco still not have a fix to it, but, in my case I disabled globally the FRA and after that the issue stopped to work.
Like you said in tour article the vlan Mapping issue is related to the FRA mechanism when it change the radios.
Hi there,
Thanks for your comment. I am also eagerly awaiting the software that will solve this problem.
Adam
