SSH problem on ESXi host before performing upgrade
wingwing
Visitor
I have install hyperflex  4.5(2e),and esxi is  version 6.7
now I want to upgrade esxi form 6.7 to 7.0,but it error with "Failed to establish SSH connection to host: Host is not reachable, or in lockdown mode"
I tried to add  below config in the esxi host and restart ssh,but it not work
echo "KexAlgorithms +diffie-hellman-group14-sha1" >> /etc/ssh/sshd_config
what can I do next to fixed this problem?
also I want to know what user is the HXPlatform to control esxi host ?    root? or other user?   if not the root ,what is the other user password?
thanks
9 Replies 9
Mark Elsen
   - @wingwing         FYI : https://www.cisco.com/c/en/us/support/docs/hyperconverged-infrastructure/hyperflex-hx-data-platform/216554-ssh-incompatibility-with-esxi-6-7p04-bu.html
  M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
 I  saw this article and I already try ,but It not work,  upgrade  fail with error "Failed to establish SSH connection to host: Host is not reachable, or in lockdown mode"
  - @wingwing        What exactly did you try ?
  M.
       Beauty and terror
      Just keep going
       No feeling is final
I tried to echo "KexAlgorithms +diffie-hellman-group14-sha1" >> /etc/ssh/sshd_config   to  the esxi host and reboot ssh  but not work
  - @wingwing     Check if the particular cipher (diffie-hellman-group14-sha1)  is listed (after the changes you made)
                                     by using the command :  nmap -p 22 --script ssh2-enum-ciphers esxi-host
        (esxi-host can be the hostname of the esxi server or it's ip address)
 M.
       Beauty and terror
      Just keep going
       No feeling is final
thanks marce
i will tried your suggestions
hi marco
   I have tried this command,and I saw the particular cipher  (diffie-hellman-group14-sha1)  is listed in the output
  but I retry the upgrade processes in hyperflex,it also error with "Failed to establish SSH connection to host: Host is not reachable, or in lockdown mode"
what can i do next to fix this problem?
 - @wingwing   Contact Cisco TAC , describe what you have done and ask why that workaround didn't help.
  M.
       Beauty and terror
      Just keep going
       No feeling is final
I'm having the same problem. Did you find a solution?
