bill of materials
hi team i got a technical details and i need a bom.
I would have loved to help, but I have very limited knowledge of the language you have used (I guess its French).
I can assure you of one thing, if you have put in the request of all the concerns, then it is a very solid BoM, the only thing I would want you to double check is the Pricing, as Pricing could vary with a great magnitude between customer to customer and partner to partner, otherwise you should be all set.
If you still have any concerns, I would suggest you to run it by the local Cisco Reseller.
Btw, if this post has helped you, please give appropriate rating :-)
Thanks n Regards
Wilson Samuel
Level 7
Level 7
Great..
Try using the Cisco CCW Tool, it will guide you step by step (makes you to include all the components of any given product including Lic)
https://apps.cisco.com/Commerce/home
Hi Wilson,
thank's for the responce,i already make my bom but i need to see if it will responce to the request of my partner.
the bom in attached
regards
Thanks n Regards
