06-01-2012 12:51 PM
Firstly, this is my first post here to apologies if it is in the wrong area.
Basically, I've just finished and am awaiting results of a degree in Computer Networking. In the meantime, I would like to gain the CCNA certification.
I have looked around the internet and the general idea i'm getting is that the only requirement is to pass the 640-802 exam, or two seperate smaller exams. Is this correct.
The only reason I ask is that CCNA was offered as part of my course, and i'm pretty sure people who signed up for it had to complete a skills test (physical network lab test) to gain the certification.
Could someone clarify what is required for the CCNA certification please?
Also, I have read a couple of bits and pieces mentionning CCNA 1, 2, 3 & 4 certifications. Are these different, invidivual, certifications to just "CCNA" on its own?
Thanks in advance for any light you can shed on this!
Solved! Go to Solution.
06-01-2012 02:01 PM
Hi David,
You are most correct here my friend! The exam can be taken as one composite exam
or split into to seperate exams;
CCNA Exams & Recommended Training | |
Required Exam(s) | Recommended Training |
| 640-802 CCNA | Interconnecting Cisco Networking Devices Part 1 (ICND1) v1.1 Interconnecting Cisco Networking Devices Part 2 (ICND2) v1.1 |
OR | |
| 640-822 ICND1 | Interconnecting Cisco Networking Devices Part 1 (ICND1) v1.1 |
| 640-816 ICND2 | Interconnecting Cisco Networking Devices Part 2 (ICND2) v1.1 |
https://www.cisco.com/web/learning/le3/le2/le0/le9/learning_certification_type_home.html
The CCNA1,2,3,4 notes that you saw are likely related to to the Cisco Academy learning modules
that is split into 4 sections
Your best bet for these type of questions is probably here;
https://learningnetwork.cisco.com/community/certifications
Cheers and best of luck with your CCNA studies!
Rob
"Show a little faith, there's magic in the night" - Springsteen
06-01-2012 02:01 PM
Hi David,
OR | |
Rob
06-02-2012 03:48 AM
Hi Rob,
Thats great, thanks for the clarification!
