Explain what is Ipsec tunneling, how it works?
hpanigra
2 Accepted Solutions
kipatra
IP tunneling (IP encapsulation) is a technique to encapsulate IP datagram within IP datagrams, which allows datagrams destined for one IP address to be wrapped and redirected to another IP address. IP encapsulation is now commonly used in Extranet, Mobile-IP, IP-Multicast, tunneled host or network.
nissaha
IPSec tunnel mode is the default mode. With tunnel mode, the entire original IP packet is protected by IPSec. This means IPSec wraps the original packet, encrypts it, adds a new IP header and sends it to the other side of the VPN tunnel (IPSec peer). Tunnel mode is most commonly used between gateways (Cisco routers or ASA firewalls), or at an end-station to a gateway, the gateway acting as a proxy for the hosts behind it.
6 Replies 6
kipatra
IP tunneling is a process to encapsulate an IP datagram with another IP datagram so as to wrap a packet and send it to destined location. GRE protocol is used for the same.
nissaha
Ipsec tunnel encapsulates/encrypts an IP packet. Adds a new header with new IP address and sends it to the ipsec peer
roravind
sadhanva
Ipsec will encapsulates data and Transmits it over secured network. provide security authentication integrity . It works in 2 modes tunnel mode and transport mode. It is a virtual secured network which uses AES and public private encryption method.
