Deploy PKCS Cert to Devices from DNAC Managed Network Devices
MSJ1
To do Tacacs+ TLS Based Auth I need to deploy Cert into the Devices ( Cisco IOS-XE ) in PKCS Format following method 2 mentioned at below URL
https://www.cisco.com/c/en/us/support/docs/security-vpn/terminal-access-controller-access-control-system-tacacs-/225097-configure-tacacs-over-tls-1-3-on-an.html
Deploying cert in every device individually will be cumbersome. Since, if I can deploy certs ( PKCS format ) to device from DNAC ? Note that Devices are managed from DNAC so DNAC has reachability to network devices for which TLS Based Tacacs+ Config will be done.
0 Replies 0
