working with DNAC 2.3
Eric R. Jones
Level 4
Level 4
So I'm working with Catalys Center 2.3.5 to learn how this thing operates and what we can do with this service. Right now we're mostly frustrated, or atleast I am. In the Provision > Inventory section I can see all our devices. Under switches we have over 120 and at least 102 of them show non-compliant since upgrading the configurations. We changed our snmp-server settings to use aes 128 vice 192 or 256 because "assurance" won't workwith either. Now the error I'm getting is related tot he tempate I built to deploy that change. The template contains "snmp-server user "USERNAME"rwsrf v3 auth sha <Password> priv aes 128 <samepassword>". I select "Non-Compliant" to see wha the result is and I get this:
I've received this type of error before related to a configuration command placed in a template and eployed. I fixed it by fixing errors in the template code. I'm not positive what this error is trying to tell me other than the "snmp-server" command is in error. I manually removed the settings from the test switch, copy run start, resync'd and waited about 10 minutes. After that I deployed the template again and same issue, rinse and repeat except this time I entered it via CLI cut and paste style. Same issue even though the tempate wasn't used.
So I removed the template from DNAC and re-ran the compliancy check and what do you know no more error. It didn't tell me explicitly what was wrong between the template and the config. I bet tomorrow morning it will be back to tease me.
DanielP211
Hello!
The SNMP part with the passwords will always give you CLI compliance errors so use the ignore CLI template violations for this part. Use it like this in the template:
! "at"start-ignore-compliance
snmp-server.,....
!"at"end-ignore-compliance
BR
****Kindly rate all useful posts*****
