Showing results forĀ
Search instead forĀ
Did you mean:Ā
Etherchannel stop communication
hhakimi
Hi After creating L2 etherchannel all the devices stop communication
Did I miss anything
I changed the mode from static to PAGP an LACP but still same
If anyone can help me will be much appreciated Thanks
bonkeselemani
check the bandwidth
if they all trunk
or all ports must allowa the same vlan
if you use PAGP make sure one side is desirable and another one auto
or you want to use LACP make sure one side is active and another passive
