CLI 3.5 error 500
Laloutre
Frequent Visitor
Frequent Visitor
I try to use the new version of CLI analyzer on my desktop in W7 and I'm facing an issue, the application is not available and I have an error 500.
Does the V3.5 is compatible with W7 like version 3.4.1 ?
I tried to reinstall the application but the issue still occurs.
Thanks for your help.
Laloutre
Frequent Visitor
Frequent Visitor
The issue is solved with Version 3.5.1.
r.heitmann
Level 5
Level 5
the current release seems to support only
* MacOS
* Windows 10
unlucky
luckydams
Visitor
I have same issue using Windows10 host. Already tried both CLI 3.5 x86/x64 distributions.
Is there any issue with our Cisco login credential ? (Since one of my peer is able to use it in same configuration.)
Thanks for your reply.
Thanks for your feedback. I have upgraded my desktop in W10 but the issue is the same.
My colleague in the same configuration has no issue and all is working fine for him.
Laloutre
Frequent Visitor
Frequent Visitor
