CLI Analyzer v3.0 Pipe
tkornowski
Visitor
I've downloaded and tried CCA and find it pretty usefull
but i can't figure out how to create the pipe symbol | in CCA.
i'm using MacOS X and Windows 7 and on both OS CCA doesn't recognize the standard OS shortcuts for the Pipe Symbol.
do i anything wrong or will this be implemented in a later Version?
best regards
Thomas
John Bollier
    If you are using a non US keyboard layout that is most likely the reason it is not working. If you can share which keyboard layout you use I can add it to our support list in a coming release.
John
7 Replies 7
John Bollier
John
Hello John,
It's the German Layout.
it would be highly appreciated if this layout is supported in one of the next releases.
best regards
Thomas
Same issue on Swedish keyboard.
br, Mikael
Hello John,
well, CLI Analyzer 3.1 is out but still no german Keyboard support 😞
any Idea when it makes it's way into a release, if at all?
Thomas
Hi Thomas,
    We are working on it and hope to have the "|" character supported for German and other popular keyboards in Europe soon.
Thanks for your patience. We haven't forgot.
John
I'm using version 3.5.0 now but still not found the "| " Pipe support for the non US keyboard.
Boo
NikolaZg350
Frequent Visitor
Frequent Visitor
I have same problem for Croatian keyboard.
