CLI Analyzer v3.6.5 - Upload failed
DavidGray77695
Frequent Visitor
Frequent Visitor
Since upgrading to 3.6.5, every file analyse I do, comes back with the error 'Cisco File Analysis is currently unavailable [UPLOAD_FAILED]'
I am seeing a lot of this on the community page, is this an issue with 3.6.5? It worked perfectly fine on the previous versions.
For reference I have tried this over the past few days, all with the same issue
AnFiPer
Community Member
I have te same problem, but this is the only version where I tried this software.
adesalawu
Community Member
Depending on your OS. Uninstall the previous download and install the newest version.
Note
For Windows run the Cisco-CLI-Analyzer.3-6-5.x64.msi file for 64bits
BR,
Adediran
I just tried that, no luck. Still the same issue unfortunately.
Depending on the OS. do a disk cleanup for your systems before re-installing. restart your systems if possible.
BR,
Adediran
