Export CLI analyzer diagnostic results
atsukane
Level 7
Level 7
Hi team,
I'm currently working on updating our vulnerability management process. (Well there was virtually none and very reactive.)
I've just configured ManageEngine NCM to generate exposed devices report which shows the Model, OS type, OS version and affected vulnerabilities with links to Cisco security advisory, this is generated daily.
As this report is just looking at device model OS and not config, there are many false positives.
I then run system diagnostics against affected devices on CLI analyzer to get more specific results. (e.g. NCM reports may flag 6 high risks, but CLI analyzer only finds 2 medium risks)
I can download the result of the system diagnostics in JSON fort per device, but is there any way of getting export of the results from all devices?  I've looked in the directory where it's installed but it doesn't seem to save any files in there.
Thanks in advance.
jofrumki
Hello @atsukane
Please check for the Tool Results files in the following path. C:\Users\<your username>\.ciscoSA\toolResults
The files will use the UUID of the devices and there should be a mention of the device serial number within the results that will properly associate the results with the device. Please look for the key-value pair "title": "The data from this device (serial number) was evaluated against x different diagnostic checks ."
jofrumki
Hello @atsukane
atsukane
Level 7
Level 7
thanks @jofrumki
It would be great if CLI analyser can generate report for all managed devices but I guess it's not that kind of a tool.
