Problem to run CLI Analyzer
steve-pang
Visitor
I am experiencing problem to run CLI Analyzer.
The software was installed properly. After I click the CLI Analyzer icon, a window pop up saying "loading, one moment please". After few seconds,  the window disappears and nothing happens.
I tried on few other PCs and all the same.
PC are using Win7
The software is Cisco-CLI-Analyzer.3-1-0.x86.msi. I tried 64bits as well.
Can anyone help?
Steve
7 Replies 7
Phillip.Joynes
Frequent Visitor
Frequent Visitor
I had the same issue.  I have fixed it by running a repair.  I hope this helps.
Phill
Hi all,
After running a repair, I still can not open CLI Analyzer on Windows 7(64-bits). Please help me or send the download link for version 2.x?
I have the same issue, did you found a way to solve it?
Ilham.Perdana
Frequent Visitor
Frequent Visitor
What OS do you use?
I had this problem too, repair and clean install didn't help any further. But after manually installed update from Microsoft (KB2670838), I able to run CLI Analyzer without any problem.
My system is Windows 7 SP1 x64.
Hope it helps
Ilham.Perdana was right, updating the Windows 7 system with this package: Microsoft (KB2670838), the application runs perfectly
Thanks a lot
Happy to hear that Juan 🙂
Mark Hardt
Visitor
Everything was fine until I ran a CLI Analyzer version update and it has been failing ever since. I tried to repair and reinstall it. No change. Anyone running Windows 7 should avoid upgrades if they are running stable.
