Jeffrey Foster
We are pleased to announce the release of Cisco UCS PowerTool Suite version 2.4.1.
Cisco UCS PowerTool suite is a set of PowerShell modules for Cisco UCS Manager, Cisco IMC and Cisco UCS Central that helps in configuration and management of Cisco UCS domains and solutions.
Key Features in Release 2.4.1
  • Support for new features in Cisco IMC Release 3.1(3a)
  • Support for new features in Cisco UCSM Release 3.2(3)
  • Updated cmdletSet-ImcHuuFirmwareUpdaterwith new parameters.
  • Updated catalog rules for M5 Servers.
Key Features in Release 2.3.1
  • Support for new features in Cisco IMC Release 3.1(1d)
  • Support for new features in Cisco UCS Central Release 2.0(1b)
  • Support for new features in Cisco UCSM Release 3.2(1d)
  • Updated cmdletAdd-UcsCentralServiceProfileFromTemplateto create Service profile with service profile template
  • Added cmdletGet-UcsCentralPolicyUsageto provide support to fetch policy details for any managed object.
Key Features in Release 2.2.1
  • Support for new features in Cisco IMC Release 3.0(1c) and 3.0(2b)
  • Support to launch the UCS Manager HTML GUI automatic login
  • Support to specify the JSON file as input for uploading the hardware profile to HCL Tool
  • Support to collect advisories for the hardware profile in HCL Tool cmdlet
  • Security enhancement to HCL Tool cmdlets
Your scripts written using PowerTool 1.x will break due to module name changes.
The following table lists the module name changes in this release:
Previous Module Name
New Module Name
CiscoUcsCentralPS
Cisco.UCSCentral
CiscoImcPS
Cisco.IMC
CiscoUcsPS
Cisco.UCSManager
Installer download (from cisco.com):
Module download (from Powershell Gallery):
  • Cisco.UCSManager
             https://www.powershellgallery.com/packages/Cisco.UCSManager/2.4.1.3
  • Cisco.IMC
               https://www.powershellgallery.com/packages/Cisco.IMC/2.4.1.3
  • Cisco.UCSCentral
              https://www.powershellgallery.com/packages/Cisco.UCSCentral/2.4.1.3
  • Cisco.UCS.DesiredStateConfiguration
               https://www.powershellgallery.com/packages/Cisco.UCS.DesiredStateConfiguration/2.4.1.3
Documentation:
Reference: Cisco UCS PowerTool Command Reference for Cisco UCS Manager
External customers - For any queries/feedback on PowerTool, contact Cisco TAC or ucs-powertool@cisco.com or add a discussion to the Cisco Developed Integrations sub-space on Cisco UCS Communities
We are also on Slack - slack requires registration, but the cisco-ucs-powertool channel on powershell team is open invitation to anyone to register here. Once you join the powershell slack team you can join cisco-ucs-powertool channel here
Internal (Cisco) customers and employees - Contact us at ucs-powertool@cisco.com for support questions and ask-ucs-tme@cisco.com or ask-ucs-pm@cisco.com for roadmap questions and feedback.
bob-sinclair
To get UCS HealthCheck v2.3 to work with PowerTool Suite version 2+ I had to replace the four references to ‘CiscoUcsPs’ with ‘Cisco.UCSManager’
http://www.advancednetworktraining.com/ucs-healthcheck-v2-3-with-powertool-suite-version-2-0-1/
Seems to work; do I have that right?
James Hester
Probably. They changed the module names when they released the suite. Mucked up a bunch of my scripts...
bob-sinclair
Page updated with the re-naming info just an hour after this comment. Thanks!
andrewjpalmer
The Confirm parameter on the Set-UcsSysdebugMEpLog cmdlet doesn't appear to be working.  Despite the below I am still being asked to confirm each blade in scope.
Get-UcsBlade | Get-UcsMgmtController | Get-UcsSysdebugMEpLog -Type SEL | Set-UcsSysdebugMEpLog -AdminState clear -Confirm:$false
Are you sure you want to modify xxxxxxxxxxxxxx:sys/chassis-1/blade-1/mgmt/log-SEL-0?
[Y] Yes  [A] Yes to All  [N] No  [L] No to All  [S] Suspend  [?] Help (default is "Y"):
Are you sure you want to modify xxxxxxxxxxxxxx:sys/chassis-1/blade-2/mgmt/log-SEL-0?
Are you sure you want to modify xxxxxxxxxxxxxx:sys/chassis-1/blade-3/mgmt/log-SEL-0?
etc
This is version 2.0.1
nveda
Hi Andrew,
-Confirm is a switch parameter in PowerTool cmdlet, if specified it will prompt for confirmation.
You can use –Force to avoid confirmation.
Get-UcsBlade | Get-UcsMgmtController | Get-UcsSysdebugMEpLog -Type SEL | Set-UcsSysdebugMEpLog -AdminState clear -Force
Thank you,
Nitin
andrewjpalmer
Thanks. I will give -Force a try.
Shouldn't the -Confirm parameter honour my request though and not confirm?  A $true or $false value returns the same result.
nveda
Hi Andrew,
In all the set and remove cmdlet in Powertool we prompt user for confirmation as it involve some change in configuration.
-Confirm parameter is honoring your request. $true and $false return different result.
PowerTool C:\> Get-UcsBlade | Get-UcsMgmtController | Get-UcsSysdebugMEpLog -Type SEL | Set-UcsSysdebugMEpLog -AdminState clear -Confirm:$false
Are you sure you want to modify Tcs-tpi01:sys/chassis-1/blade-1/mgmt/log-SEL-0?
Yes Yes to All No No to All Suspend Help (default is "Y"): n
PowerTool C:\> Get-UcsBlade | Get-UcsMgmtController | Get-UcsSysdebugMEpLog -Type SEL | Set-UcsSysdebugMEpLog -AdminState clear -Confirm:$true
Confirm
Are you sure you want to perform this action?
Performing the operation "Set" on target "Tcs-tpi01:sys/chassis-1/blade-1/mgmt/log-SEL-0".
Though it appears similar these are different messages. When you say –Confirm:$false , message that you see is a confirmation we need from user to do any configuration.
As I mentioned in my earlier mail you can try -Force
C:\> Get-UcsBlade | Get-UcsMgmtController | Get-UcsSysdebugMEpLog -Type SEL | Set-UcsSysdebugMEpLog -AdminState clear -Confirm:$false –Force
Let us know if it helps.
Thank you,
Nitin
andrewjpalmer
I am trying to deploy this silently to a bunch of remote desktop servers but the installation is freezing.  After testing I found that if the installer finds a powershell.exe process running the installer freezes because it wants you to close the process before installation.  Can you please ensure that this is popup is not happening when a silent install is requested?  At most the installer should just suggest a reboot is required.
sumbr
Level 4
Level 4
Hi Andrew,
Thanks for sharing your feedback. We will fix this issue in the next release.
Sumanth BR
andrewjpalmer
Actually I think I am wrong.  I have just tested this on a server with nobody installed and it's still freezing.  I'm actually deploying via DSC.  It's upgrading version 2.0.1.5 to 2.2.1.8.  Here's what I am using.
Package CiscoUCSPowerTool
    Ensure = 'Present'
    Name   = 'Cisco UCS PowerTool Suite'
    Path = 'C:\Cisco_UCS_PowerTool_Suite_2.2.1.8.msi'
    ProductId = 'A696D9A4-F116-4881-954F-5AE448CF80AD'
    Arguments = '/qn /norestart'
Not that it helps but here's the verbose output...
VERBOSE: [SERVER01]:                            [[Package]CiscoUCSPowerTool] The package Cisco UCS PowerTool Suite is not installed
VERBOSE: [SERVER01]: LCM:  [ End    Test     ]  [[Package]CiscoUCSPowerTool]  in 0.2960 seconds.
VERBOSE: [SERVER01]: LCM:  [ Start  Set      ]  [[Package]CiscoUCSPowerTool]
VERBOSE: [SERVER01]:                            [[Package]CiscoUCSPowerTool] Validate-StandardArguments, Path was C:\Cisco_UCS_PowerTool_Suite_2.2.1.8.msi
VERBOSE: [SERVER01]:                            [[Package]CiscoUCSPowerTool] The path extension was .msi
VERBOSE: [SERVER01]:                            [[Package]CiscoUCSPowerTool] Parsing A696D9A4-F116-4881-954F-5AE448CF80AD as an identifyingNumber
VERBOSE: [SERVER01]:                            [[Package]CiscoUCSPowerTool] Parsed A696D9A4-F116-4881-954F-5AE448CF80AD as {A696D9A4-F116-4881-954F-5AE448CF80AD}
VERBOSE: [SERVER01]:                            [[Package]CiscoUCSPowerTool] Ensure is Present
VERBOSE: [SERVER01]:                            [[Package]CiscoUCSPowerTool] product installation cannot be determined
VERBOSE: [SERVER01]:                            [[Package]CiscoUCSPowerTool] product as boolean is False
VERBOSE: [SERVER01]:                            [[Package]CiscoUCSPowerTool] Package configuration starting
VERBOSE: [SERVER01]:                            [[Package]CiscoUCSPowerTool] Mount share to get media
VERBOSE: [SERVER01]:                            [[Package]CiscoUCSPowerTool] Starting C:\Windows\system32\msiexec.exe with /i "C:\Cisco_UCS_PowerTool_Suite_2.2.1.8.msi" /quiet /qn /norestart
VERBOSE: [SERVER01]:                            [[Package]CiscoUCSPowerTool] Starting process C:\Windows\system32\msiexec.exe with arguments /i "C:\Cisco_UCS_PowerTool_Suite_2.2.1.8.msi" /quiet /qn /norestart
It freezes here and never ends.  I did notice if I kill a "msiexec.exe*32" process the installation then completes OK...
PS C:\Windows\system32> Get-Module cisco.ucs.core -ListAvailable
    Directory: C:\Program Files (x86)\WindowsPowerShell\Modules
ModuleType Version    Name                                ExportedCommands
Binary     2.0.1.5    Cisco.UCS.Core                      {Get-UcsCcoImageList, Get-UcsCcoImage, Get-UcsPowerToolCom...
PS C:\Windows\system32> Get-Process -Id 14120 | Stop-Process
Confirm
Are you sure you want to perform the Stop-Process operation on the following item: msiexec(14120)?
[Y] Yes  [A] Yes to All  [N] No  [L] No to All  [S] Suspend  [?] Help (default is "Y"): y
Binary     2.2.1.8    Cisco.UCS.Core                      {Add-UcsHardwareProfile, Get-UcsPowerToolCommunity, Get-Uc...
And the remaining verbose output...
VERBOSE: [SERVER01]:                            [[Package]CiscoUCSPowerTool] The machine requires a reboot
VERBOSE: [SERVER01]:                            [[Package]CiscoUCSPowerTool] Package has been installed
VERBOSE: [SERVER01]:                            [[Package]CiscoUCSPowerTool] Package configuration finished
VERBOSE: [SERVER01]: LCM:  [ End    Set      ]  [[Package]CiscoUCSPowerTool]  in 1017.6410 seconds.
VERBOSE: [SERVER01]: LCM:  [ End    Resource ]  [[Package]CiscoUCSPowerTool]
VERBOSE: [SERVER01]:                            [] A reboot is required to progress further. Please reboot the system.
WARNING: [SERVER01]:                            [] A reboot is required to progress further. Please reboot the system.
As you can see the time it took was 1017 seconds which is how long it took me to figure out killing the 32bit process finished the install.
brrood
Sumanth,
Will this new release support connecting to UCSM 3.1.3 that came out in April?
Bryan
sumbr
Level 4
Level 4
Hi Bryan,
You should be able to connect to UCSM 3.1.3 with the current release of UCS PowerTool Suite. However, cmdlets for the new features (MOs) is not available.
In UCSM 3.1.3 domain if the SSL protocol version is set to TLS 1.2 then before making a connection you need to include the below line in your script.
[System.Net.ServicePointManager]::SecurityProtocol =[System.Net.SecurityProtocolType]::Tls12 -bor [System.Net.SecurityProtocolType]::Tls11 -bor [System.Net.SecurityProtocolType]::Tls -bor [System.Net.SecurityProtocolType]::Ssl3
Sumanth
luis.silva1
Community Member
Hi.  I need some help.
I’m having difficulty figuring out how to run a specific query using UCS PowerTool.
Basically I need to scan all my UCSes and check if VSAN trunking is enabled or not on a SAN Fabric.
I might be searching in the wrong place/command for the information.
Thank-you for any help.
-Luis
alberto_vargas
Community Member
I agree that PowerShell gallery is the way to go. As a customer seeing an MSI package (PSSnappin) over a powershell module makes me question the maturity of the product.
amimanda
Hi Alberto,
Modules have been posted on PSGallery now.
Amit Kumar
