Cisco UCS PowerTool Core suite is a set of PowerShell Core modules for Cisco UCS Manager, Cisco IMC and Cisco UCS Central, that helps in the configuration and management of Cisco UCS domains and solutions. Cisco UCS PowerTool Core modules are develo...
Cisco has released the 4.0(0) version of the Cisco UCS Manager VMware vSphere HTML remote client plugin. The UCS Manager vSphere HTML client plugin enables a virtualization administrator to view, manage, and monitor Cisco UCS physical infrastructure...
Cisco UCS PowerTool Core suite is a set of PowerShell Core modules for Cisco UCS Manager, Cisco IMC, Cisco UCS Common and Cisco UCS Central, that helps in the configuration and management of Cisco UCS domains and solutions. Cisco UCS PowerTool Core ...
How can the following be configured using the Cisco UCS Power Tool for IMC (Cisco C240)?Server# scope biosServer /bios # set boot-order hdd,cdrom,fdd,pxe,efiServer /bios *# commitServer /bios # show detailI can find cmdlets for configuring Advanced b...
Hello, my Name is Rohitkrishnan. I recently graduated from a Tier 4 college without any placement assistance. I am actively searching for roles and continually improving my technical skills. Cisco, being a top MNC, providing me with an internship opp...
i have a ucs c220 working properly, but would like to access in cimc interface and i don't have the correct user and password. what is the best way to reset that?
Cisco UCS PowerTool Core suite is a set of PowerShell Core modules for Cisco UCS Manager, Cisco IMC and Cisco UCS Central, that helps in the configuration and management of Cisco UCS domains and solutions. Cisco UCS PowerTool Core modules are develop...
Howdy folks (by the way, there is no good 'label' for this question), I've got a Python script going out to many sites around the world to query both 'ComputeRackUnit' and 'ComputeBlade' class IDs. This is across everything from M2s (almost gone!) t...
Cisco UCS PowerTool Suite is a set of PowerShell modules for Cisco UCS Manager, Cisco IMC, and Cisco UCS Central, that helps in the configuration and management of Cisco UCS domains and solutions. Cisco UCS PowerTool modules are developed using the ...
