Vijay Balyan
Installation:
  •      Using pip:
     pip install ucsmsdk
  •      Using Github:
     Install pip (skip if pip is already available):
          wget https://bootstrap.pypa.io/get-pip.py
          python get-pip.py
     git clone https://github.com/CiscoUcs/ucsmsdk.git
     cd ucsmsdk
     make install
Uninstall:
     pip uninstall ucsmsdk
Documentation:
     https://CiscoUcs.github.io/ucsmsdk_docs/
Samples:
    GitHub - CiscoUcs/ucsmsdk_samples
Features 0.9.8 (2019-01-22)
  • Support for UCSM release 4.0(2a)
Features 0.9.6 (2018-12-11)
  • Support for UCSM release 4.0(1b)
Features 0.9.5 (2018-10-10)
  • Updated requirements to include setuptools
Features 0.9.4 (2018-08-13)
  • Fixes for Python 3 compatibility
Features 0.9.3.2 (2018-04-25)
  • Support for UCSM release 3.2(3a)
  • Support for accepting array arguments in query_classids, query_dns
  • Support for setting response timeout for the UCSM operations (query/config)
  • Handling auto_refresh flag in unfreeze
  • Fixing issue with None value check of property by removing None check from validation of property/check_prop_match
  • Fixing issue where error happens with commit when threading is enabled and commit buffer is empty
  • Fixing issue where ssl with "Only TLS 1.2" does not work
Features 0.9.3.1 (2017-01-25)
  • Removed jsonpickle dependency
Features v0.9.3.0:
  • Support for estimating impact of a transaction - handle.estimate_impact
  • Support for TLS 1.1, 1.2 Newer UCSM releases support TLS1.2. HTTPS connection to the servers with newer releases might fail in absence of TLS1.1/1.2 support.
  • Added command line script to make running convert_to_ucs_python easier. bin/watch_ucs.py in the github repo.
  • Special characters like <,>,& in XML values are deemed invalid and cause failure in parsing XML. Added a recovery logic if these exist in the XML value fields.
  • Support for serialization, deserialization of UcsHandle
  • Support for UCSM inventory via get_inventory API
Features v0.9.2.0:
  • Support for UCSM 3.1(2b)
  • Adds Support for Generating python APIs from a Ucs backup xml -
    convert_from_backup
  • Adds Infra to facilitate and notify users of API deprecation
  • Allows the ucsmsdk/apis layer APIs to pass in None values to indicate that no
    change is requested to those specific params
  • Adds a method to check if the handle.cookie is still valid
  • Fix in eventhandlers, where some events were not getting processed
  • Fix in eventhandlers, where timeout was not getting triggered until new
    events
  • Fix in get_ucs_tech_support, where techsupport for rack server was failing
  • Fix in logout, where a Ctrl+C was causing stale connections on the server
  • Deprecated get_ucs_tech_support in favour of get_tech_support. The newer
    API simplifies the API
Features v0.9.1.1:
  • Support for UCSM 2.2.7
  • Simplified event handlers to a single wait_for_event method. UcsEventHandler internals are hidden from user.
  • Support for showing progress for upload/download operations
  • Support for multi-threading in SDK. An application can run multiple threads that can use SDK methods in parallel.
  • Support for multiple parallel transactions via the tag parameter in add_mo, set_mo, remove_mo, commit_mo
  • Fix for convert_to_ucs_python exception in some scenarios
  • Fix for convert_to_ucs_python not displaying python script for Java6u45
  • Fix for event handlers not trigerring for some events
  • Added more unit and system tests
  • Better Documentation
Features v0.9.1.0:
  • Support for UCSM 3.1.1
  • Support for Python 3.x
  • Support for Comparing and Syncing Objects across Ucs Domains - compare_ucs_mo sync_ucs_mo
  • Support for filter_str in query_children method
  • Support to drill down into Managed Object Meta and Property Meta details - get_meta_info
  • Support to monitor any/all change(s) in a ManagedObject with UcsEventHandler
  • Fix for Unable to make unsecured connection when redirection was enabled on the server
  • Fix for issues with the usage of force parameter in Login method
  • Fix for not filter not generating filter request
  • Fix for TechSupport not getting removed from server even when remove_from_ucs=True
  • Fix for convert_to_ucs_python not redirecting output to a file
  • Fix for convert_to_ucs_python not working correctly when gui_log=True
  • More PEP8 compliance related fixes
Features v0.9.0.0:
  • Python SDK for UCS server management and related automation
  • Supports every Managed Object exposed by Cisco UCSM
  • APIs for CRUD operations simplified for usability
  • convert_to_ucs_python - API to generate Python script based on operations done on the UCSM UI
  • Support for server side filters made simpler
  • Support for eventhandlers
  • Parameter validation on the client-end
  • Runtime memory usage is reduced
  • logging support
  • Nosetests for unit testing
  • Samples directory for more real world use cases
  • Integrating the sphinx framework for documentation
  • PEP8 Compliance
Github:
      https://github.com/CiscoUcs/ucsmsdk/
PyPi:
https://pypi.python.org/pypi/ucsmsdk/0.9.1.1
A slide-deck in markdown describing some of the changes:
     stash/slides.md at master · CiscoUcs/stash · GitHub
Community:
     We are also on Slack - slack requires registration, but the ucspython team is open invitation to anyone to register here
Quick reference for PythonSDK  commands is available  for download.Please find it attached below as
LE-45204-PythonSDKPoster.pdf
Note:
     0.9.1.0 is not backward compatible with any of the earlier SDKs. It is re-written to be more pythonic and moves away from the earlier JAVA like syntax.
aranatar
Rahul,
Thanks for the reply. I tried exporting "export PYTHONHTTPSVERIFY=0" and ran the auto discovery. that was able to do the job.
~Aravind
parterda
Community Member
Most of the time handle.login() is hanging forever.
I am creating handle as below
handle = UcsHandle("IP/host", "username", "pwd")
handle.login()
Some time i see this first time or while firmware activation. On server reboot boot UcsHandle is not able to establish the connection.
i tried with force=True option too.
Thank you in advance..
Parisa
parterda
Community Member
Root cause for this issue.
in ucssession.py
self._tx_lock_acquire_conditional(elem)
        if self._is_stale_cookie(elem):
            elem.attrib['cookie'] = self.cookie
        self.dump_xml_request(elem)
        xml_str = xc.to_xml_str(elem)
        response_str = self.post_xml(xml_str)
        self.dump_xml_response(response_str)
self._tx_lock_acquire_conditional(elem) is not released in case of exception at response_str = self.post_xml(xml_str)
And when login attempt is made during server is rebooting we get an exception and this lock will not be released unless we restart the program.
self._tx_lock_release_conditional(elem) needs to be added in except block.
ashish-pimple
Community Member
I am getting AttributeError , will you help me.
[root@ansible ucsmsdk]# java -version
openjdk version "1.8.0_102"
OpenJDK Runtime Environment (build 1.8.0_102-b14)
OpenJDK 64-Bit Server VM (build 25.102-b14, mixed mode)
[root@ansible ucsmsdk]# python
Python 2.7.5 (default, Aug  2 2016, 04:20:16)
[GCC 4.8.5 20150623 (Red Hat 4.8.5-4)] on linux2
Type "help", "copyright", "credits" or "license" for more information.
>>> from ucsmsdk.utils.ucsguilaunch import ucs_gui_launch
>>> from ucsmsdk.ucshandle import UcsHandle
>>> handle = UcsHandle("192.168.224.148", "ucspe", "ucspe")
>>> handle.login()
True
>>> ucs_gui_launch(handle)
2017-05-26 07:24:11,925 - ucs - DEBUG - AuthToken: <17591998066782747766531>
2017-05-26 07:24:11,925 - ucs - DEBUG - UCSM URL: <https://192.168.224.148:443/ucsm/ucsm.jnlp?ucsmToken=17591998066782747766531>
2017-05-26 07:24:11,926 - ucs - DEBUG - javaws path: </bin/javaws>
2017-05-26 07:24:12,006 - ucs - DEBUG - Temp Directory: </tmp>
Traceback (most recent call last):
  File "<stdin>", line 1, in <module>
  File "ucsmsdk/utils/ucsguilaunch.py", line 119, in ucs_gui_launch
    raise e
AttributeError: 'NoneType' object has no attribute 'groups'
[3]+  Stopped                 python
[root@ansible ucsmsdk]# cat /etc/redhat-release
Red Hat Enterprise Linux Server release 7.3 (Maipo)
Ashish
While debugging more I have observed that ucsguilaunch.py is not able to create a file in tmp named temp.jnlp.
So I download ucsm.jnlp manually at /tmp and renamed it as temp.jnlp. But when I execute ucs_gui_launch again, it is deleting manually created file temp.jnlp.
Commenting below line in ucsguilaunch.py is not helping as well.
79   if os.path.exists(jnlp_file):
80                    os.remove(jnlp_file)
So it looks like it is not able to recreate temp.jnlp again. Am I missing anything.
Ashish
ben.crook
Community Member
i have an issue. i have a multi-threaded program for python it collects multiple component info not just cisco on multiple threads.. so i kick off some code (a thread for cisco stuff) to get ucsm logs and chassis logs from a ucs system...  so each get_tech_support call for logs (ucsm and chassis logs) are each their own thread as well, even for multiple chassis each chassis would be on a thread, getting all logs at the same time. i do delay starting of the threads each by 20 secs just in case.. so i have several labs that this works perfect on but those labs only have 2 chassis in them nothing more.
now when i run this on a customer's system that has like say 8 chassis! there seems to be issues, the exception msg that comes back is "TechSupport creation timed out" ... now it has happened on 2 different customer sites where they had 8 chassis. it would always get (from what i could tell) ucsm logs and chassis 1 logs, but would fail on either getting chassis 2 through 8 or 3 through 8.
again it's multi-threaded so i'm getting the ucsm logs and all the chassis logs at the same time from the same UCS system. i NEVER have issues on a 2 chassis only ucs system.
if this is known issue or limitation??  i can provide my code if needed
UPDATE
turns out the limitation is within ucs, you can't even get multiple chassis at the same time via the ucsm gui .
kfudge1980
Level 2
Level 2
Is the SDK going to be updated with any kind of HTML GUI launch and python conversion function?
halperin amit
Visitor
Hello, i want to create on my cisco servers raid 1 with automation, i tried to do that with redfish api but It doesn't allow me to do that.
What can i do? what tool i can use to do it(create physical raid with the raid controller), i think the "cisco ucs python sdk" can't help me...
