Intersight Hyperflex Edge Cluster deployment using Terraform
jachbr29857
Visitor
Wondering if this related to the fact that we are running the Private Virtual Appliance and not the SaaS model of Intersight?
Receiving the following error when trying to create a profile for HX Edge clusters. I have set the storage_type = "HyperFlexDp" as well as commented out this to use the default which is showing "HyperFlexDp". Using the version 1.0.1 provider, terraform 0.14.7, Hyperflex 4.0(2d) and Intersight 1.0.9-197 Private Virtual Appliance
Error: failed while creating HyperflexClusterProfile: 400 Bad Request Response from endpoint: {"code":"InvalidRequest","message":"Cannot create or modify the object ''. The property 'hyperflex.ClusterProfile:StorageType' does not exist.","messageId":"barcelona_request_property_does_not_exist","messageParams":{"1":"","2":"hyperflex.ClusterProfile","3":"StorageType"},"traceId":"NBd1050ced215dcfb867203ad6e1d2bce6"
resource "intersight_hyperflex_cluster_profile" "cluster_profile" {
for_each = var.site_specifics
name = each.value["cluster_name"]
mgmt_platform = var.management_platform
// storage_type = "HyperFlexDp"
organization {
object_type = "organization.Organization"
moid = intersight_organization_organization.org_data.moid
mgmt_ip_address = each.value["hx_mgmt_ip"]
mac_address_prefix = each.value["mac_prefix"]
// wwxn_prefix = var.wwxn_prefix
storage_data_vlan {
vlan_id = var.storage_vlan_id
padramas
Can you please try this issue after upgrading the private appliance to latest version 1.0.9-250 ?
