How to access serial in a docker container?
Paulo Seguel
is there a way to tell a docker container to use a serial device in the IR829?
I know that a typical Docker container can be granted serial device access with "docker run --device=/dev/ttyS3 ..."
But how do I tell to the ioxclient/local manager to grant serial device access to a package?
Steve Zhang
You need to set the serial port in the file of package.yaml. Please refer to Cisco DevNet: IOx - Docs (go to Python Application Using Serial Port as an example for using serial port)
Cisco DevNet: IOx - Docs, in this link we can see the examples for creating docker files, Yaml and container, but we couldn't found any serial port example with Yaml,
we are getting following error for the python example link provided
Is there any serial port example for docker container with Yaml file
