Edge Computing Infrastructure
Labels
Hi,I am using IR809 router with "IOx bundle image of ir800-universalk9-bundle.SPA.156-2.T1" and the Guest OS installed by default with the bundle.I am using the  SDK 1.1.0 for application development. I am following LXC Applicaton Development on Cisc...
bharat3 by • Community Member
  • 1590 Views
  • 1 replies
  • 1 Helpful votes
Hi,we are testing the latest firmware/GOS combination that was provided to us regarding lxc container installation:Firmware: ir800-universalk9-bundle.SSA.156-2.0.49.GBGOS: ir800-ioxvm-1.1.0.4-T.binEverything seems fine with our container software, bu...
Hi guys,IR 809 fails to boot properly if the USB storage is inserted during power up. Boot stucks in rommon-1> and there's no way to make it run. I tried to bootHV from the usb drive but this failed as well. If I try to dir there are some errormessag...
gkujawsk by • Level 1
  • 3505 Views
  • 3 replies
HiI wanted to use IOx debug commands to see why my GOS is not starting. I entered "debug iox", as shown below, and then tried to start the GOS. The GOS is not starting, as shown by the result of the "show iox host list detail" command, but nor do I s...
nathan by • Level 2
  • 4325 Views
  • 3 replies
