How to use numpy module for Python on IR829(IOx)?
ys-hasegawa
Community Member
Is there a way to use the numpy module for Python in the IR829?
Please teach me how to use numpy module on IOx.
I make the following PaaS App and deploy it.
Deployment successfully complete, but App Status: STOPPED after a few seconds.
requirements.txt
flask
numpy
main.py
from flask import Flask
import numpy as np
app = Flask(__name__)
@app.route('/')
def test_numpy():
    test = np.arange(10)
    return str(test[0])
if __name__ == '__main__':
    app.run(host='0.0.0.0',port=9000)
the following error occur(WATCHDOG.LOG):
APP START TIME:1505979890 App NumTest started with PID : 231 Monitoring this process now App TestApp completed with exit code: 1 APP END TIME:1505979890 Time taken by App : 0 minutes and 0 seconds. Stopping the container
So I change main.py to the following.
It's RUNNING.
main.py
#import numpy as np
@app.route('/')
def test_numpy():
    #test = np.arange(10)
    return "Hello World"
Steve Zhang
You may access the app console for debugging and troubleshooting.
https://developer.cisco.com/site/iox/docs/#debugging
I think the cause is because numpy needs fortran.
Thank you for answering.
