how to reset catalyst 3650
arjitsabu
Can someone help me to reset my catalyst-3650 to factory defaults From the switch:  prompt
switch: dir flash:
Directory of flash:/
85185 drwx 4096 .
2 drwx 4096 ..
85186 -rw- 82672260 cat3k_caa-base.SPA.03.06.00E.pkg
85187 -rw- 6601404 cat3k_caa-drivers.SPA.03.06.00E.pkg
85188 -rw- 33747948 cat3k_caa-infra.SPA.03.06.00E.pkg
85189 -rw- 42769724 cat3k_caa-iosd-universalk9.SPA.152-2.E.pkg
85190 -rw- 25711500 cat3k_caa-platform.SPA.03.06.00E.pkg
85191 -rw- 98462528 cat3k_caa-wcm.SPA.10.2.102.0.pkg
85192 -rw- 2097152 nvram_config
85193 drwx 4096 dc_profile_dir
85195 -rw- 556 vlan.dat
85197 -rw- 257651868 cat3k_caa-universalk9.SPA.03.03.05.SE.150-1.EZ5.bin
85198 -rw- 289970248 cat3k_caa-universalk9.SPA.03.06.00.E.152-2.E.bin
778772480 bytes available (869122048 bytes used)
M02@rt37
hello @arjitsabu,
flash_init
rename flash:config.text flash:config.old -- i don't see :config.text
boot flash:cat3k_caa-universalk9.SPA.03.06.00.E.152-2.E.bin
Best regards
M02@rt37
hello @arjitsabu,
flash_init
Best regards
But when I restart the switch after saving the configuration,its showing like this :
The System is using a non-recommended Boot mode.
Not all features may be available in this boot mode.
Please check the product configuration guide.
--- System Configuration Dialog ---
Enable secret warning
In order to access the device manager, an enable secret is required
If you enter the initial configuration dialog, you will be prompted for the enable secret
If you choose not to enter the intial configuration dialog, or if you exit setup without setting the enable secret,
please set an enable secret using the following CLI in configuration mode-
enable secret 0 <cleartext password>
Would you like to enter the initial configuration dialog? [yes/no]:
Do you know how to solve this...
arjitsabu
yes bro this was a helpfull this turned to a reset.
thank you so much brother for your support
