How to know the autostart script running when IXM reboot
nijie150810
Dear Folks:
I use the IXM at standalone mode. I create a autostart script and put it into the container's etc/init.d. How can I know this script running when IXM reboot.
Please help to advise
Ni Jie
mhj@conscia.dk
You can try, to take a look, at the setup from TTN https://www.thethingsnetwork.org/
/Morten
pgrosset
As indicated in the other reply, please look at
https://www.thethingsnetwork.org/docs/gateways/cisco/setup.html
Patrick
MikeStral
This is how I do...
  1. gateway> enable
  2. gateway# request shell container-console
  3. bash-3.2# top
  4. Look for the row "pkt_forwarder"
Mikael
