cisco packet tracer installation on kali linux errors
jabrahamjohn
I have been trying to install packet tracer from Cisco after installing Kali Linux in a new machine, and this is what has been happening with the same consistent error. in earlier versions of Debian Dist, the Cisco packet tracer worked fine. Later on the following dependencies will be obsolete (libgl1-mesa-glx, libxcb-xinerama0-dev).
i have raised the issue with kali linux bug tracker and it was referred to as a cisco issue...i have attached sample photos for the errors acquired. please help
Screenshot_2024-03-06_12_49_10.pngScreenshot_2024-03-12_15_35_41.pngScreenshot_2024-03-12_15_48_25.png
Blue_Bird
Hello jabrahamjohn ,
One of our member has encountered the similar issue...he solved it by performing the following steps:
The two dependencies that refused to install were:
1) libxcb-xinerama0-dev
2) libgl1-mesa-glx
I simply installed the first one by opening my terminal and typing "sudo apt install libxcb-xinerama0-dev" and it worked.
Now, for the second dependency which was "libgl1-mesa-glx", I manually downloaded the file which was gotten from https://packages.debian.org/sid/libgl1-mesa-glx.
Scroll down and choose your architecture and click on it. When you get to the next page, choose any mirror link you want to start the download(it's a deb file).
When the download is done, open your terminal and type "sudo dpkg -i dependency_name.deb" and click enter or use a package installer to install it.
When the installation is done, try installing packet tracer by typing "sudo dpkg -i packet_tracer.deb" and click enter. This should install packet tracer finally for you.
I hope this helps.
Best regards
******* If This Helps, Please Rate *******
Blue_Bird
2) libgl1-mesa-glx
I hope this helps.
Best regards
*****THIS REALLY A 100% WORKS*****. PLEASE TRY THIS METHOD OUT.
Nice, BUT somebody left just the files for RISC architecture, so, for AMD64, I have used THIS (re)source:
# DOWNLOAD required package MANUALLY !!!
~ Libgl1-mesa-glx Download (DEB)
https://pkgs.org/download/libgl1-mesa-glx
~ Debian Main amd64 (Official):
libgl1-mesa-glx_22.3.6-1+deb12u1_amd64.deb Debian 12 Download
https://debian.pkgs.org/12/debian-main-amd64/libgl1-mesa-glx_22.3.6-1+deb12u1_amd64.deb.html
http://ftp.de.debian.org/debian/pool/main/m/mesa/libgl1-mesa-glx_22.3.6-1+deb12u1_amd64.deb
And, now do what you have mentioned in your solution:
``` z-bash
# SO, use this package for your computer architecture AMD64 !!!
┌──(dragancajic㉿kali)-[~/Downloads]
└─$ sudo dpkg -i libgl1-mesa-glx_22.3.6-1+deb12u1_amd64.deb
# FINALLY, NOW install Packet Tracer 8.2.2 for Debian/KALI Linux √
└─$ sudo dpkg -i Packet_Tracer822_amd64_signed.deb
└─$ packettracer --version
Starting Packet Tracer 8.2.2
Hava a nice day and CHEERS!
★  in Cyrillic  |     in Latin     | in plain English
Драган Ћајић / Dragan Ćajić / Dragan Cajic
P.S. Just a couple of screenshots to have for your convenience!
So, let's see what we have here:
jabrahamjohn
thanks a ton; it worked big up
