Heads Up :
The post you are writing will appear in a public forum. Please ensure all content is appropriate for public consumption. Review the employee guidelines for the community here.
Hi Guys - anyone who tried creating a Windows 10 VM in CML 2.9?It seems that it cannot detect the boot partition on the disk.Here is my node definition id: win10boot: timeout: 300 uses_regex: falsesim: linux_native: libvirt_domain_driver: kvm ...
I have used my personal email address to create an account to buy CML personal. After buying the product, I am not able to download the ova and iso files because it keeps asking me to update my physical address. Looks like there is a mandatory field ...
Hello, I tried to export the lab configuration as a YAML file, but the 'ip routing' command is missing from the post-export configuration.I’ve tried manually adding it to the YAML and IOS_config.txt files, but the changes don’t seem to take effect.My...
Hi,I need to extend the 32GB of memory which was assigned by default for SDWAN Manager node.Is this possible? If yes, how can I do this? Are there any caveats I should be aware of?
Hello,I'm trying to import a .yaml file to CML but I'm getting the following error: "Failed: Error importing topology file. VIRL2 import error: YamlTopologyImportException: 'timestamp'"Does anyone know how to fix this issue? I'm running Windows 11 P...
Hello all, I was searching for a table of CML resource node requirements a few weeks ago, but couldn't find them, so I created my own table. Let me know if it helps, or if any corrections are needed.
Hello, I have CML 2.8.1 (Ubuntu 24.04.3 LTS) just installed and I wanted to run Software Updates. The update is unsuccessful, as I get the message: The following packages have unmet dependencies:libglapi-amber: Breaks: libglapi-mesa How do I fix it?
Hi, we have deployed CML 2.8 on baremetal and are hoping there is a way to adjust the system memory utilisation limit of 80%? Our server has 256GB of RAM and an 80% limit on large servers is quite a waste. We were hoping to be able to run at least a ...
Hello,I installed the "free version" of Cisco CML.When I wanted to start a node within a lab, the following message is displayed:Cisco-switch1: No compute host can start nodes, rejecting all node starts (cml-controller does not have base images.I was...
Iv recently switched my CML instance from VMware to a baremetal installation, what I would like to know is how do I upload the refplat files to the server so that I can mount them to CML like you usually would using the cockpit, does this have to be ...
I am new to CML and have been trying to set up an IP address for my end user (desktop). For some reason, whenever I start the desktop and try to open console it just hangs... Same for Vnc. I then get server errors and have to manually close down my V...
I have installed CML on my vmware workstation pro 25 H2 and 2.9 ova file. but when i try to power on nodes vmware crashes. I have disabled Hper- V and Device credentials on a Windows 11 pro OS. I am trying to install again workstation but gives error...
Hi, I upgraded CML to 2.9.1. Since upgrade the server is randomly disconnecting. This didn't happen on previous version 2.8.1 hw: intel i9 14K 24core. 96gb ram ( 90gb allocated to vm on vm workstation) and 300mb disk. VM CPU 4/2. Wont work with any...
Create a Docker container for CML 2.9 Unlock the full potential of Cisco Modeling Labs (CML) 2.9 with native Docker container support! This step-by-step guide shows you how to build a custom FreeRADIUS Docker container with debugging enabled, integra...
I am trying to upload ios-xe 17.18.02 to CML and everything seems to go ok. I downloaded the cat9k_iosxe.17.18.02.SPA.bin from cisco, converted it to qcow2 using qemu-img and then created new image definition for the image. I can then choose the imag...
