CML Lab Active (with error)
samuelbravo0863
I reserved the cisco modeling lab but it failed to properly execute the setup script and I never received the second email with the anyconnect info. This has happened to me several times in the past and the only solution I could find was to end the lab and try again after the 2 hour reservation was over.
Is there another way to fix it without having to end the lab? I've seen other posts mention the same issue and it seems the only resolution is for a cisco employee to manually fix it. I pasted the logs bellow:
Environment Driver Setup has begun
Beginning sandbox setupPreparing connectivityApps deployment startedApps are being discovered...Connecting all appsApps are powering on...Waiting for apps IP addresses, this may take a while...Error occurred during "Configuration" stage, See additional entries in the Activity Feed for more information.15:25:00 ERROR: OOB Setup script returned errors
Driver:UDC_EnvironmentDriver_E_v02
Function:call_OOB_setup_script
15:25:00 Errors occurred preparing environment.
15:25:00 Driver Complete.
baltej.giri
Hello Fellow learner,
Has anyone got a solution to this issue? I went to Cisco DevNet Sandbox to start the CML lab and got the same error.
