Multicast Lab Auto-RP
ftermine83
Hi ALL,
I have setup a lab in CML for testing multicast using Auto-RP but I cant see traffic flowing from the source to the receivers . I can see the (S,G) entry in the first hop router and the (*,G) entry in the RP .
Appreciate any feedback
Francesco
33 Replies 33
that what I try to know why, if direct connect then R1 need to know RP IP from R3 not from R2
MHM
at the moment R1 is learning the RP from R2 so it should work . I just think it is an issue with CML . I took a packet capture and I dont see the Register message being sent by  R1 when the source start transmitting
To he honest' I run lab abd it work in gns3' but I dont think it CML sunce you mention that you change R1 with NSK and it work' or I am wrong?
MHM
Yes If I replace R1 which is IOSv with a Nexus it works . I was saying I think it is an issue with IOSv in CML
