Hello everyone, I would like to share a recent case to check if anyone has experienced something similar or has any recommendations/workarounds. We have a Nexus N9K-C9516 that experienced a crash, requiring a reboot to restore service. Since then, th...
I configure both cores (1 & 2).Create a VRF for each int VLAN.And default route for each vrfBecause router connect to Core1I create on this router two sub-ints, one for vrf DMZAnd another for Inside-ZoneSo the default route for VRF DMZ, inside each c...
In an environment where SD-Access multi-site is configured, each site is used as a relay switch using C9500-32C. Each site uses Inline Tagging to propagate SGTs, and all sites share the same SGT and SGACL control. We are considering replacing the rel...
Hi, i have customer have problem with fan speed. my customer`s opinion was fan should be more faster. The N9K-C93108TC-EX have 47C temperature and 70% fan speed, transceiver have 65C. The Other one have 27C temperature and 70% fan speed, transceiver ...
Hi,I would like to ask a question about the Cisco Nexus 7k.I only administer a secondary VDC and do not have access to the default VDC. I want to prevent all users of the default VDC from entering my VDC by executing the "switchto vdc command". Is th...
