ISE 2.2 Wired 802.1X with PEAP-EAP-TLS Authentication method
amar05
Hello folks ,
I need  to configure wired 802.1x with PEAP-EAP-TLS Authentication method. So , please guide me to implement  the same and share document / link if anyone knows or already did this . As i didn't get more information regrading same from Google. Below are some details of information which we used to configure above requirement.
Project Requirement : Wired 802.1x with PEAP-EAP-TLS Authentication method.
1) Supplicant ( Embedded linux os )  [ client machine ]
2) ISE-2.4 ( Used as Radius server )
3) Cisco Switch with 802.1x port enabled ( SG300-52 52-Port Gigabit Managed Switch )
NOTE :  Standard linux operating system like ubuntu , centos is not having  such Authentication method .
santoshbajimaya
I have recently worked on the 802.1x port security for my organization. I tested it successfully in Cisco 2960 series. I have prepared a QRG for the same. The infrastructure that i used is somewhat different from yours, but i think i will help you.
Thank You
