05-10-2023 01:57 PM
I purchased a catalyst C1000 Non-Poe 8 port internal power "C1000-8T-2G-L" . It came with a twist & Lock power cable, which I cannot use. I cannot find the part number for this switch in any cisco docs. Can anyone help?
05-10-2023 03:37 PM - edited 05-10-2023 03:38 PM
All the part numbers from this device you can find here
Part number |
Description |
Compatibility |
CAB-CONSOLE-RJ45 |
Console Cable 6 Feet with RJ-45 |
All models |
PWR-CLP |
Power Cable Restraining Clip |
All models |
Cisco Catalyst 1000 Series rack mounting kit |
RCKMNT-19-CMPCT= |
19” Rack Mount bracket for C1000, 3560-CX and 2960CX |
All 8/16 port models |
RCKMNT-23-CMPCT= |
23” and 24” Rack Mount bracket for C1000, 3560-CX and 2960-CX |
Product number |
Description |
Cisco Catalyst 1000 Series Switches with 2x 1GSFP and RJ-45 combo uplinks |
C1000-8T-2G-L |
8x 10/100/1000 Ethernet ports, 2x 1G SFP and RJ-45 combo uplinks |
C1000-8T-E-2G-L |
8x 10/100/1000 Ethernet ports, 2x 1G SFP and RJ-45 combo uplinks, with external PS |
C1000-8P-2G-L |
8x 10/100/1000 Ethernet PoE+ ports and 67W PoE budget , 2x 1G SFP and RJ-45 combo uplinks |
C1000-8P-E-2G-L |
8x 10/100/1000 Ethernet PoE+ ports and 67W PoE budget, 2x 1G SFP and RJ-45 combo uplinks, with external PS |
C1000-8FP-2G-L |
8x 10/100/1000 Ethernet PoE+ ports and 120W PoE budget, 2x 1G SFP and RJ-45 combo uplinks |
C1000-8FP-E-2G-L |
8x 10/100/1000 Ethernet PoE+ ports and 120W PoE budget, 2x 1G SFP and RJ-45 combo uplinks, with external PS |
Cisco Catalyst 1000 Series Switches with 2x 1G SFP uplinks |
C1000-16T-2G-L |
16x 10/100/1000 Ethernet ports, 2x 1G SFP uplinks |
C1000-16T-E-2G-L |
16x 10/100/1000 Ethernet ports, 2x 1G SFP uplinks with external PS |
C1000-16P-2G-L |
16x 10/100/1000 Ethernet PoE+ ports and 120W PoE budget, 2x 1G SFP uplinks |
C1000-16P-E-2G-L |
16x 10/100/1000 Ethernet PoE+ ports and 120W PoE budget, 2x 1G SFP uplinks with external PS |
C1000-16FP-2G-L |
16x 10/100/1000 Ethernet PoE+ ports and 240W PoE budget, 2x 1G SFP uplinks |
Cisco Catalyst 1000 Series Switches with 4x 1G SFP uplinks |
C1000-24T-4G-L |
24x 10/100/1000 Ethernet ports, 4x 1G SFP uplinks |
C1000-24P-4G-L |
24x 10/100/1000 Ethernet PoE+ ports and 195W PoE budget, 4x 1G SFP uplinks |
C1000-24FP-4G-L |
24x 10/100/1000 Ethernet PoE+ ports and 370W PoE budget, 4x 1G SFP uplinks |
C1000-48T-4G-L |
48x 10/100/1000 Ethernet ports, 4x 1G SFP uplinks |
C1000-48P-4G-L |
48x 10/100/1000 Ethernet PoE+ and 370W PoE budget ports, 4x 1G SFP uplinks |
C1000-48FP-4G-L |
48x 10/100/1000 Ethernet PoE+ ports and 740W PoE budget, 4x 1G SFP uplinks |
Cisco Catalyst 1000 Series Switches with 4x 10G SFP+ uplinks |
C1000-24T-4X-L |
24x 10/100/1000 Ethernet ports, 4x 10G SFP+ uplinks |
C1000-24P-4X-L |
24x 10/100/1000 Ethernet PoE+ ports and 195W PoE budget, 4x 10G SFP+ uplinks |
C1000-24FP-4X-L |
24x 10/100/1000 Ethernet PoE+ ports and 370W PoE budget, 4x 10G SFP+ uplinks |
C1000-48T-4X-L |
48x 10/100/1000 Ethernet ports, 4x 10G SFP+ uplinks |
C1000-48P-4X-L |
48x 10/100/1000 Ethernet PoE+ ports and 370W PoE budget, 4x 10G SFP+ uplinks |
C1000-48FP-4X-L |
48x 10/100/1000 Ethernet PoE+ ports and 740W PoE budget, 4x 10G SFP+ uplinks |
Cisco Catalyst 1000 Series Switches with 2x 1GSFP and RJ-45 combo uplinks and 2x 1G SFP uplinks |
C1000FE-24T-4G-L |
24x 10/100 Ethernet ports, 2x 1GSFP and RJ-45 combo uplinks and 2x 1G SFP uplinks |
C1000FE-24P-4G-L |
24x 10/100 Ethernet PoE+ ports and 195W PoE budget, 2x 1GSFP and RJ-45 combo uplinks and 2x 1G SFP uplinks |
C1000FE-48T-4G-L |
48x 10/100 Ethernet ports, 2x 1GSFP and RJ-45 combo uplinks and 2x 1G SFP uplinks |
C1000FE-48P-4G-L |
48x 10/100 Ethernet PoE+ and 370W PoE budget ports, 2x 1GSFP and RJ-45 combo uplinks and 2x 1G SFP uplinks |
