Help with Cisco 1921 router
mjcurtis
Hi there,
I bought a Cisco 1921 router off of eBay, and I'm having trouble preparing for the initial configuration.
Here's what I receive after connecting to the console port:
"mcurtis@MCURTIS-VHRYWFGF0V ~ % screen /dev/cu.usbserial* 9600
open(): Open Error = -1
usbflash1: not present
System Bootstrap, Version 15.0(1r)M16, RELEASE SOFTWARE (fc1)
Technical Support: http://www.cisco.com/techsupport
Copyright (c) 2012 by cisco Systems, Inc.
Total memory size = 512 MB
CISCO1921/K9 platform with 524288 Kbytes of main memory
Main memory is configured to 64 bit mode with ECC disabled
Readonly ROMMON initialized
usbflash0: not present
rommon 1 >"
Then, here's what I get after I try to boot from a USB:
"rommon 15 > dir usbflash1:
program load complete, entry point: 0x80903000, size: 0x4c4a0
 fnuhcd5200OpenPipe  ERROR opening PIpe CVMX
*** TLB (Load/Fetch) Exception ***
Access address = 0x26
  PC = 0x8090f0c0, SP = 0x80902dc0, RA = 0x8090f560
  Cause Reg = 0x80000008, Status Reg = 0x504080e3
monitor: command "dir" aborted due to exception"
How do I get past this?
Thanks!
5 Replies 5
 When you ran dir usbflash1: you should be able to see what is in there.  Make sure the USB has the right format and it seems it is not recommended to use USB driver bigger than 2Giga.
mjcurtis
The USB is a 32GB SanDisk in FAT format. I will try again with another flashdrive.
Yeah just use a smalller one and see.
mjcurtis
Got this after today after trying with a 1GB flashdrive
rommon 6 > dir usbflash1:
