Part number for ISR4331/K9 ?
Mosasa
I have a ISR router with a broken FP. Trying to order a new face plate but don't know and can't find the part number for the face plate.
Router is ISR4331/K9.
Thank you!
I actually found the part number for the face plate! It's ACS-4330-BEZEL.
Thanks! for taking the time to look through the receipts/bills.
lpersing
Hello, I looked through a few bill of materials from when I ordered 4331/K9 routers and I don't see a part number for the plastic face plate. It might be best to buy one off of ebay. The closest thing that I can see is a blank for the SM slot with a part number SM-S-BLANK.
balaji.bandi
yes, i agree, buy any used equipment and replace it with a broken one. personally, this is not effective for the router performance, so I will ignore it, At some point you may require the uplift router.
BB
To be clear, Mosasa is looking for a face plate and not a router. If he was looking to replace a router he would best be served ordering a replacement from Cisco.
