All 8 ports are routed interfaces. This asa doesn't work like a switch. You can create sub interfaces using specific vlans on each but they'll be different zone even with the same security level; this means rules apply between interfaces using a acl, same-security command, ...
You have to use it as full routed interfaces and not switching.
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
