Leap second on GSS
loveandrew821
Hi all, I hope everything you doing goes well.
I'd like ask if any one knows about the leap second on GSS. actually I found the workaround for this issue that I should  turn ntp feature off, 2 days
before the leap second and turn it back on after that time...however, I am concerned if that action gives any affect on service....
I don't want take the risk so I want to make sure if I can do this job.
I will be waiting for your wise answer thank you.
Patrick Schneider-Sturm
Dear customer,
thank you for your message.
Let me send you a link to provide you more information about the leap second issue.
http://www.cisco.com/web/about/doing_business/leap-second.html#~Overview
I hope that helps and answers your questions.
best regards
Patrick
Thank you for the answer and I had a look at the link well.
however the doc shows the workaround only and what I want to know is If I follow the workaround->
If I turn the ntp off, will the gss service stop????? or the service countine???
Dear Customer,
I'm sorry i didn't quite catch exactly what you wanted.
We try to answer every question as soon as possible but since you raised this question in the ServiceGrid Community (we are ITSM professionals) i'm afraid i do not have the answer for your question.
However, my colleagues in the following community might have the answer you are looking for:
https://supportforums.cisco.com/community/5876/application-networking
Please raise your question in this community in order to get an answer quickly.
best regards
Patrick
