A problem with a .pka file of Cisco Packet Tracer course
Andy117
Hello everyone this is Andy, I was doing this activity (2.1.1 packet tracer create a simple network) and when I try to edit the last fields of the instructions I´m unable to do it, It only shows a text that says: "blank".
Another problem that is apparently occuring is a problem with the "Subnet Mask" of the PC, It shows that is Incorrect, when It is not.
Also the exercise is stuck in 75%.
I really apreciate if you can help me with this.
Thank you
Martin L
What is IP and mask right now? Are there any other clues ?  you can keep trying various masks until u get correct one.
Attach your PT file here in a zip format; PT files must be zipped in order to be attached here
Regards, ML
**Please Rate All Helpful Responses **
Nightranger
For me, IP/Subnet are both correct - However I am unable to input in the input fields.
If I hover over, I get the cursor change to show it's an input, and I can "Highlight" the field which highlights the word "blank", yet it will not accept any input from the keyboard, I am unable to copy/paste the fields into each other and thus, It is also stuck at 75% meaning the task is unable to be completed.
