C9407r Power Shutdown
moakintola
I have 2 C9407R in stackwise virtual. Then there is multiple power outage on both, then the startup-config disappeared each time I apply power back.
I was applying the backup config each time to restore the network.
But now:
1. remote/ssh stopped working (Error: Session stopped, Network error: Software caused connection abort) - see screenshot 1 attached
2. console also working (showing only banner but no prompt for username and password) - see screenshot 2
5 Replies 5
Leo Laohoo
What firmware is the VSS on?
Raise a TAC Case and ask TAC to verify if this is CSCvs71697 or CSCwa86696.
ROM: IOS-XE ROMMON
BOOTLDR: System Bootstrap, Version 16.12.2r, RELEASE SOFTWARE (P)
@moakintola wrote:
ROM: IOS-XE ROMMON
This output is useless.
Please post the complete output to the command "sh version".
Cisco IOS XE Software, Version 16.12.04
Cisco IOS Software [Gibraltar], Catalyst L3 Switch Software (CAT9K_IOSXE), Version 16.12.4, RELEASE SOFTWARE (fc5)
Copyright (c) 1986-2020 by Cisco Systems, Inc.
Compiled Thu 09-Jul-20 21:49 by mcpre
ROM: IOS-XE ROMMON
CATALYST 9407-01 uptime is 5 days, 10 hours, 17 minutes
Uptime for this control processor is 5 days, 10 hours, 20 minutes
System returned to ROM by PowerOn at 11:36:08 NIG Tue Aug 8 2023
System image file is "bootflash:packages.conf"
Last reload reason: PowerOn
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Technology Package License Information:
Technology-package Technology-package
Current Type Next reboot
network-advantage Smart License network-advantage
dna-advantage Subscription Smart License dna-advantage
AIR License Level: AIR DNA Advantage
Next reload AIR license Level: AIR DNA Advantage
Smart Licensing Status: UNREGISTERED/EVAL EXPIRED
cisco C9407R (X86) processor (revision V01) with 1867864K/6147K bytes of memory.
Processor board ID FXS2351Q2CC
61 Virtual Ethernet interfaces
96 Gigabit Ethernet interfaces
64 Ten Gigabit Ethernet interfaces
4 Forty Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
16010152K bytes of physical memory.
11161600K bytes of Bootflash at bootflash:.
11161600K bytes of Bootflash at bootflash-2-0:.
1638400K bytes of Crash Files at crashinfo:.
1638400K bytes of Crash Files at crashinfo-2-0:.
234430023K bytes of SATA hard disk at disk0:.
234430023K bytes of SATA hard disk at disk0-2-0:.
0K bytes of WebUI ODM Files at webui:.
