Cisco Firewall Upgrade Readiness Check Problem
Hello friends,
I get an insufficient disk space warning during the readiness check step before FTD upgrade. Even though I deleted the old version files I uploaded, there was no space on the disk. Has anyone encountered this problem before? From which directory should I delete files, which files can I delete?
****************** FAILURE SCRIPT: 1 ***********************************
[240429 15:41:28:672]
SCRIPT NAME: 000_start/410_check_disk_space.sh
RECOVERY MESSAGE: Not enough disk space available in /ngfw(Filesystem:/dev/mapper/var) to perform the upgrade.(Current available disk space: 19232320KB. Minimum required disk space: 20008092KB).
rnan
Hi, I think you need to ask TAC team to solve this issue
