Cisco Modeling Labs. Installation issue, please help?
MicJameson1
Hello.
https://www.cisco.com/c/en/us/td/docs/cloud_services/cisco_modeling_labs/v200/quick/start/b_cml_quick_start_2-0/m_deploy_and_configure.html#Cisco_Task.dita_36dc85f9-0f4f-467b-8b33-4cae626219f6
Some questions please:
1. Is it REQUIRED that CML is installed on a VM, or optional?
2. Must i install an OS on the VM, then install the CMP software, or do I install CML as the operating system?
3. from the above link...
"Preparing for Installation. Before you can start the installation, first download the software. Download the CML controller OVA and the refplat ISO files."
Below are my downloaded files. Are one of these files the OVA?
cml2_2.4.1-34_amd64-13
cml2_2.4.1-34_amd64-13.iso.signature
CML-IMG-REL-CCO_RELEASE.pem
Thank you.
7 Replies 7
I get free access to CML, waiting the Code
when I get it and run CML and share notes with you
thanks
balaji.bandi
- CML 2.5 you can install on bare metal now, also you can install as VM.
Look at the latest version guide :
https://developer.cisco.com/docs/modeling-labs/?_=1#!cml-installation-guide
No CML its self has OS and install as VM - check above installation guide
If you installing as VM you need below files :
BB
As I know cml need  vm,
He can use vmware player (free edition )
FYI :
BB
I follow david bombal and I sure he need vmware.
I will share link of video here later
MHM, your link is very helpful. I'll return to this post when ready. Thanks as always!
