Cisco Proximity - Does not find room system
SE1989
Hi team,
I'm having a strange problem with 4 Macbook Pro's at work. All of them do not find the room system. So far I have done following troubleshooting.
  • Checked Microphone if its working
  • Checked if Mic was used by another problem
  • Uninstall/Reinstall
  • Checked if machines were connected to Corp Wifi
  • Checked if users had headset connected via bluetooth, remove if any device connected
Is there anything else I should check for?
Thank you all.
0 Replies 0
