How to add Dual Port LAN card module in Cisco Packet Tracer for PC?
Asad Mirza
Dear Concern,
Can i add dual port LAN card for PC in cisco packet tracer, in PC module there is no any type this module which have dual LAN port. So, how can i add module and where i can download from?
@Asad Mirza
 This is not possible. If you rover over the option you are going to see always "single interfaec" or "one ethernet" interface.
M02@rt37
Hello @Asad Mirza
Cisco Packet Tracer does not natively support dual-port LAN cards or modules for PCs. The available modules for PCs in Packet Tracer are limited to what is provided within the software, which typically includes single-port network interface cards.
But, use instead a PC a server to add second NIC:
This can simulate a PC with multiple LAN ports...
Best regards
