How to enable HTTPS SSL on Smart Satellite 6_10 while accessing with browser
ong
Frequent Visitor
Frequent Visitor
When typing https to access to the Smart Satellite 6_10, the https is  marked as non secured.
https://x.x.x.x:8443/admin#/mainview/
https://x.x.x.x:8443/#/SmartLicensing/
In the Smart Satellite 6_10 user guide it is stated:
Interface Support SSM satellite EE adds support for multiple interfaces (up to 4) to be configured and used for User management, Product Registration, and communications with CSSM. However, only 2 interfaces can use HTTPS. The number of interfaces listed in the Network Interface tab is dependent on the number of interfaces provisioned on the host.
Note: While all interfaces will show up, only eth0 and eth1 can be used for strict HTTPS communication with products. The remaining interfaces can be used for either web access, or products which register with either HTTP, or that do not perform strict SSL checking.
I'm runing on the SW in a VM with ens interface.
Do i need to access to centos root for certificate install ?
Thanks a lot for your help!
regards
bb
AKohler07
Frequent Visitor
Frequent Visitor
now its available.
Version  7-201910
Andreas
