Issue with Airprint on iPad and global http proxy setting Meraki MDM
eevans33
Sometime over the last couple of weeks, something has changed either in Airprint on ipads or the way the Meraki MDM global http proxy setting is applied.
With a proxy setting pushed out by Meraki as the global http proxy, the ipad cannot connect to the airprint printers. They appear in the list of found printers, but when one is selected it goes straight back to the print screen with "No printer selected" as the printer.
If I remove the global proxy setting pushed out from Meraki, and apply the same proxy settings manually, it works absolutely fine (as it has always done in the past).
Has anyone else seen this issue, or have any idea how to pursue a fix?
Many thanks, Emma
0 Replies 0
