Packet Tracer question - cable modem?
mikecressey
I am newbie to using Packet Tracer. I'm running one of the labs in the Introductory course and it requires using a cable modem. I am running 7.2.2 which is clearly newer than the version of PT used in the tutorial.  I have searched the entire menu and I cannot find a cable modem.  Is it now some other device or is it no longer supported?  If so, is there a substitute that I can use to complete the lab.
Thanks.
Mike
16 Replies 16
No problem glad to help...
celine.vs
I had the same issue. Is that a fault in the course that it states to use a copper straight-through connection?
