We have just received new ASR9906 routers and I am unable to configure the host key for the SSH system to use.
the command çrypto key is not available within the configuration menu.
Also the MD5 function does not appear to be operating within the OSPF packets as the attached routers are reporting the ospf packets do not have MD5 digest.
Is there a license required to have these functions enabled?
We have the following packages active on this router:
Node 0/RSP0/CPU0 [RP]
Boot Partition: xr_lv43
Active Packages: 8
asr9k-xr-6.5.3 version=6.5.3 [Boot image]
asr9k-mpls-x64-2.0.0.0-r653
asr9k-eigrp-x64-1.0.0.0-r653
asr9k-k9sec-x64-2.1.0.0-r653
asr9k-mpls-te-rsvp-x64-2.1.0.0-r653
asr9k-ospf-x64-1.0.0.0-r653
asr9k-isis-x64-1.1.0.0-r653
asr9k-mcast-x64-2.0.0.0-r653
Node 0/RSP1/CPU0 [RP]
Active Packages: 8
Node 0/0/CPU0 [LC]
Active Packages: 8
Node 0/1/CPU0 [LC]
Active Packages: 8
