probleme de configuration SIP to SIP
angembaki2002
bonjoue cher support
J ai un probleme quand je fait un test sur mon routeur avec la commande
_SIPTRUNK#csim star 0041XXXXXXX
% Invalid input detected at '^' marker.
voici ma configuration pouvez vous m aider a soir si j ai manquer un element ? ou j ai oublier d activer un parametre ?
je ne parvirn pas a faire un test d appel avec la commande dans le routeur
voice service voip
media disable-detailed-stats
allow-connections sip to sip
no supplementary-service sip handle-replaces
redirect ip2ip
sip
redirect contact order best-match
voice class media 1
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g722-48
codec preference 4 g722-56
license udi pid ISR4321/K9 sn FDO22222NBY
license boot level uck9
license boot level securityk9
license smart enable
username Cisco password 0 Cisco
redundancy
mode none
vlan internal allocation policy ascending
interface GigabitEthernet0/0/0
ip address 192.168.10.4 255.255.255.0
negotiation auto
interface GigabitEthernet0/0/1
ip address 10.108.XXX.XXX 255.255.255.252
negotiation auto
interface GigabitEthernet0/1/0
interface GigabitEthernet0/1/1
interface GigabitEthernet0/1/2
interface GigabitEthernet0/1/3
vrf forwarding Mgmt-intf
no ip address
negotiation auto
interface Vlan1
no ip address
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 10.108.XXX.XXX
ip route 10.108.XXX.XXX 255.255.255.255 10.145.1XX.XXX
ip route 10.108.XXX.XXX 255.255.255.255 10.145.XXX.XXX
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
dial-peer voice 40035 voip
preference 5
destination-pattern 0043
session protocol sipv2
session target ipv4:10.145.XXX.XXX
voice-class codec 1
dial-peer voice 123 voip
destination-pattern [12]...
dtmf-relay sip-notify
gateway
timer receive-rtp 1200
sip-ua
retry invite 3
retry register 3
timers register 150
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login local
0 Replies 0
