Radius Server Dead/ Alive Problem/Flap
OJ_Magellan
Hi All,
I'm getting the following Radius message on a 9300 IOS XE 17.3 Switch:
373543: Apr 16 12:29:12.104: %RADIUS-4-RADIUS_DEAD: RADIUS server x.x.x.x:1812,1813 is not responding.
373556: Apr 16 12:33:24.563: %RADIUS-4-RADIUS_DEAD: RADIUS server x.x.x.x:1812,1813 is being marked alive.
The Radius Server (ISE) is pingable, and I've used the "test aaa ... " Command to see if the authentication works, and it did as intended.
Any Idea what might be the Radius server keeps flapping?
The radius source interface is Loopback 0
OJ
I read some where when the Deadtime is not config then the Radius Server flap Dead/alife so just config the Dear Time and see the result.
Do you mean the following command?
radius-server deadtime xxx
OJ
Did that command fix your issue? What values did you use to correct this?
