Replacement suggestion for Cisco AP AIR-CAP3702I-AZBLK
ssubron
Is there any suggestion to replace AIR-CAP3702I-AZBLK?
I am not able to see it in the EoS link (https://www.cisco.com/c/en/us/products/collateral/wireless/aironet-3700-series/eos-eol-notice-c51-740710.html).
I am also not able to create an estimate for it on CCW.
Please let me know.
Sanjay
 After 3700 AP we have the 3800 it would be a replacement for you but 3800 already have a replacement by Cisco Catalyst 9130AX Series Access Points.   As Cisco must be focusing  in Catalyst AP which is 802.11ax, and 3700 is only AC, it is difficult to have a directly comparison.
Leo Laohoo
I cannot answer this simple question without understanding the LAN situation:
  1. Can the switch support uPoE (up to 40wac)?
  2. Does the LAN backbone support 10 Gbps (or higher)?
